tery
Silvia survived the purge- summer car
So, this will take a few more days, but look at one someone had pieced together...I'll have to re-do some bolts cause too rusty for even PB, but it all should come out fine when all is said and done.
btw, I tried the system of using progressive grits on headlight lens...and it really does work terrifically. So far I finished one fish tank..I think it is called...I did one side of the head, but started with 2000...So when I saw it finished I decided to start with 1000. That did the job to get out the pits and such so that 2000 on up to 12000, gave a really smooth and clear finish.
It was very tedious to get apart the lens, but I have to share with you that I found a great tool for that job, It is call... isesame...it is used for opening I pads and phones and such and worked really well to get the lens separated from the frame, after some serious "drawing" with sharp carpet knife on the clearly glued parts.
Here's what someone has cobbled together with zip ties and duct tape...
