hypnotic
I have problems with bucking under load and I ran some codes here they are:
556-Fuel Pump Relay primary circuit fault
121-Closed throttle voltage higher or lower than expected
122-Throttle Position sensor below minimum voltage
157-Mass Air Flow sensor fault, low voltage
542-Fuel Pump relay secondary circuit fault
543-Fuel Pump relay secondary circuit fault
I got the MAF low voltage before and I just cleaned it and it went away, but that was only a couple of days ago. I'd like to know more about the primary and secondary fuel pump circuit fault.
Any input would be helpful.
-Craig
-Craig
