Harmonic Balancer Threaded Holes
93SHO_2
Omaha Nebraska
What is the size of the 2 threaded holes in the harmonic balancer? I tried 7mm, 8mm with 1.00 and 1.25 threads distance and 5/16 with 18 pitch and 24 pitch, nothing seemed to fit.
I drilled them to 5/16 then tapped them to 24 threads per inch, used two 2 inch length bolts and had plenty of clearance, but I don't think I should of had to go thru all that.
They are M8, coarse thread and that size bolt usually comes with any damper puller kit.
Edit: Thanks Gary, I was going from memory and was mistaken.
<small>[ November 12, 2003, 12:24 PM: Message edited by: sdpatt ]</small>
gmorrell
Never been a noob...
Colorado Springs, CO
sdpatt:
They are M10, coarse thread and that size bolt usually comes with any damper puller kit.
Uhhh, no, they're not 10mm. They're M8-1.25. The threads in the damper were probably a bit dirty/corroded and needed chased with a tap.
And just because I'm an ****-retentive, picky SOB, its not a harmonic balancer, its a harmonic damper. :D The Yamaha's rotating assembly is by nature, zero-balance, and doesn't require any additional balancing.
twr
whoohoo
half-way there, I think.
Of course there is no need to verify, but there are indeed M8-1.25. I had to buy some to pull the damper when I did my engine upgrade. Nice to see you posting here Gary.
<small>[ November 13, 2003, 11:20 AM: Message edited by: twr ]</small>
93SHO_2
Omaha Nebraska
Thanbks for the clarity, it is a balancer on my 68 302 J code, when did things change? wink
I'll include the bolts if I ever sell the car.
V6Hova
trenton,nj
I had the same thing happen to me. I tried metric (fine and coarse) and standard but nothing would work. After about 3 hours of trips to the hardware i was messing with it when I noticed it move. I pulled the damn thing off with my fingers. Anyway the threads were messed up from the person before me. I just retapped them from the back. But i almost did the same thing as you (drill and retap).
