H support
dunsgamer
Florida
has anyone installed a H support or bracket? What improve ments are there and is it worth it?
Irish Pride
Irish Inside
MusicCityUSA
It makes a perfect rear jack point to get both wheels off the ground at the same time. For that reason alone it's worth it. I have one on both my SHOs.
intimdatr
Got Cams?
Jefferson City, Missouri
Pretty much.
It may stiffen up the rear but I installed mine with the ingalls control arms so i noticed a large difference over stock but it was likely the combo.
DJSHO91
Durham, NC
It stiffens up the rear end mounts and reduces some of the rear-end "waddle" over rough roads. :salute:
jayro
Auburn, In
On a stock suspension SHO you probably are not going to see any handling improvememnts. On a SHO that is driven in rack conditions with aftermarket rear cotrol arms it would help reduce flex by providing a solid/rigid connection poit.
Also is a nice jack point....as already stated.
