Marccus
When changing my front brake pads, I had to replace my left front rotor because it was severely grooved on the inside.
I thought this was due to the extremely worn brake pad.
After only several months, I again found the left front rotor had an extremely deep groove on the inside.
There is no noise when driving, braking, or turning. The car runs straight as an arrow when I let go of the steering wheel and there is no vibration.
I cannot detect anything rubber the rotor when I inspect it visually. :headbang:
What is "grooving" the rotor?
Since the pads are in constant contact with the rotor )even when the brakes are not applied), I assume there must be an uneven pressure on the brake pad from the rotor piston, causing one point to rub ******* the rotor.
Will caliper replacement solve the problem?
Any help would be appreciated.
'89 SHO with 296,000 mi. Original calipers.
