Grinding Clutch
ctm78
Chicago, IL
Last week my clutch started feeling "weird" when all the way in. There is a very light grinding feeling coming through the pedal. It almost feels like the brake pedal when the ABS is engaged.
There are no grinding sounds, and I can still shift normally. This only occurs when the clutch pedal is fully depressed, if you let out just a little bit it goes away.
Any thoughts?
masho95
got Zex?
Chicopee, MA
Doesn't sound quite right... sounds like something going on with the TOB and PP fingers.
autobahnsho
SHO Victim
NY for now, WY for real
As with all clutch issues, start first by adjusting it. Pull UP on the pedal w/ about 10 lbs. of force. If you hear a click it means it tightened the cable.
(Better explanation in the owner's manual.)
I'd agree, if it keeps doing it your throwout bearing and pressure plate are probably getting torn up. But I'm not entirely sure.....
