SHOguy 92
Not a SHO build, but I'm bored of just lurking and I'm sure some of you wouldn't mind seeing this. Anyways, about a month ago my GP's tranny went, I had some plans for the summer, it's basically got every bolt on possible + a cam. I didn't have on a aftermarket TB, MAF, or IC, but I had all of them just sitting here waiting for summer. I then could make some good power, but my stock tranny was holding me back from going to a full size IC and shooting for some serious power. But when the tranny went, I tossed a lot of money at a built trans, and a full size IC kit, and a lot of other things, and heres the workings so far (Shooting for 360 - 370whp).
First off, heres another pic besides my sig pic of the car
Here's the IC Kit in all it's glory
And here's a comparison of the IC core I was goign to use (on the right) and the new one I am using (on the left).
Here's the SC after I yanked it off the car, and a shot of how it will look on the IC core
And here's the SC all painted up
Along with painted valve covers
Here's the GTX under surgery, and just a look at how huge the IC Front Mount Heat Exchanger is, it will require a bit of cutting to make fit.
And here's the lower intake manifold with a massive section cut out so it matches the IC Core size for more surface area to **** heat.
Going to go do some more work on the beast tonight, forgot my camera yesterday. But I torqued the LIM back on and then set the IC core and SC on top of it to see if they would actually fit under the hood, and they barely did thank god. Will be some sexy pictures of that tonight.
I just kept looking at new parts and saying "well might as well do it once and do it right" and the total kept going up, next year will most likely get a Res, Nitrous, and some DR's and try for a high 10's pass, that or go turbo.
