Got night pictures of Fish tank lights
charliejon
Minneapolis
I saw how to do the conversion, but can't find the post... could you tell me how you did it? Thanks.
It's SHO Time
Gillette, Wyo
well, first if you have the parts it's alot easier than it seems, what I did was, take your headlight assembely out and your side makers lens out, then what I did was took a normal drill bit and drilled a hole into the center of fish tank lights then I took a 5/8 wood bore bit and made a bigger hole, then after I made the hole I washed them out so all of the plastic pieces where gone, then on the side maker lights I cut the side maker free (it has the same pigtail, and light bulb) and left room to strip the wires back, then I put the boughten pigtail in the fish tank (may need to cut the plastic back on the pig tail for it to fit good) then ran some 14 gauge wire from the wires going to the side maker and then spliced the the side marker light in and taped it all up. If I confused you you can go where I went to figure it out at:
http://www.shotimes.com/php-bin/modules.php?op=modload&name=News&file=article&mode=thread&order=0&thold=0&sid=197
have fun and take your time doing it right, it will look nice, too.
