Got my dual valve catch can installed
VanillaBoost
Rochester, NY
well, finally got my catch can installed. It should work very well. Need some miles before I see can drain
any stuff from the canister. I can tell ya is was a real pita trying to find a place to mount it. Where I did is basically the "only" place I could find to do it and believe me I looked over the engine bay for quite some time. I color coded the hoses so it was easier to glance and know which end goes where. I had to modify the mounting
bracket as well. The pic of the kit shows only the parts needed for this mod. I needed to keep in mind since this is a universal kit, so there was a few more parts that were not needed, just confused things a bit.
Brown is "clean air" in to the front bank via the oil fill cap.
Red is "dirty air" from the back bank to the canister to be cleaned.
Green is "cleaned air" from the canister into the front bank and into the intake at the throttle body.
bpd1151
Lurking Around
SHOcago 'Burbs
I gotta give credit, where credit's due.... very VERY clean install.
Well executed. Points for that alone.
Brumfield780
