Gen1 rocker cover mldg retainer (HELP)
qshipsho
NJ
Can anyone tell me where I can get the rocker cover moulding retainer? It is rivited on and rusted badly....wanted to remove the mouldings prior to paint and now I can't find a replacement. Ford says they are no longer made and no one has one!?"#@*%##*!
F-22 Raptor SHO
7015 feet above Sea Level
The metal L bracket or the plastic retainer clips?
qshipsho
NJ
retainers/grommets
I am talking about the long retainer(about 4ft long) that is rivited to the rocker. It is rusted beyond help, the rocker panel is fine!! Need to replace just the retainer...the little ones on the qtr pnls and L-shaped ones on the fenders are reuseable. I also need the grommets that snap into the doors which the upper door mldings clips, snap into.... They are little round grommets, off white in color...They are for an 89..
etc1006
Baltimore, Md.
I need to do the pass. side on my 93... Its actually sticking off the rocker some and you can see in there... Rocker is fine like yours. AFAIK you just have to find a good used one. I'm gonna get the one off the parts car at my JY. Of course its only got one good one... Either that or I'm gonna try to make one.
qshipsho
NJ
What I may do is use a few sections of what I have..after looking at this big retainer...its sole purpose is to hang and secure the rocker cover moulding in place. If I cut the less rusted sections of the retainer in four small sections and rivit them on spaced across the rocker evenly...they should work. Besides, where am I going to find 15 + years old non-rusted retainers from...
SHO_Driver
Montreal, QC
Yeah I just made new ones out of plastic, no more corrosion issues! Could also do them in aluminum or new metal.
mrecoolgar
SHO NUP
Hershey-PA
I can help with the grommet retainers. I have new stock at $0.50 each. They are not cheap. Rear doors require 5 each and the front doors require 7 each.
I also carry other specialized fasteners and hardware.
On a side note. If you have access to a nutsert gun I would use them (8-32 size) instead of rivets. That way they are easily removable if needed.
Just my 2 cents.
