GEN III SHO and SLO subframe question
boat
Likes blue ones
Tallahassee, FL
From what I understand it is the gen 3 SLO subframe used for the subframe upgrade to the gen 1 and 2.
the Gen3 SHO subframe has motor mounts significantly different from the slo subframe, and it is not conducive to rework to fit on Gen1/2 cars.
you should have no trouble locating a Gen3 slo subframe at a junk yard, and there are a couple threads here detailing what to do to modify it to work on your 90.
Phoenix
SHOHOLIC
QC , Canada
I got a GEN4 slo subframe on my 2002 :evilgrin:
You have to mod it anyways , might as well take one thats available.
rbruso
unlikely
Tucson, AZ
The GEN4 takes the same control arms as the GEN3? Good to know.
I assume the ZF rack mounts right up?
Phoenix
SHOHOLIC
QC , Canada
Haven't tried it , but good chances that it will. The whole suspension setup in a GEN4 is basically the same (except the coils and struts (valves inside must be different). They look the same but part numbers on rockauto are different.
