Fuel quick-disconnect
FastAndFurious
Washington
Hope this will be the last thing I need to fix for a while.
Fuel is leaking where the fuel quick-disconnect is. I'm pretty sure I need to buy special tool and o-rings for that. Do you guys know what size of o-rings they are? I know they are brown o-rings but can't figure out what size they are. Also, where can I buy those o-rings? I checked some auto stores, but seem like they don't have the o-rings. Ford dealership?
K-Dawg
Treasure Coast, FL
Parts stores usually carry a selection of O-rings. You can get the plastic tools to disconnect those lines there, also.
FastAndFurious
Washington
Hm. Ok. I was looking at some parts stores but seem like they don't have brown o-rings. I'll try to look for them again. Thanks.
FastAndFurious
Washington
Does anyone know what size o-rings they are?
I know it's either 390847-S96(1/2") or 390846-S96(3/8"). Which one is right one for sho?
FastAndFurious
Washington
Ok. If no one knows about that, what about this? I was looking at RockAuto website and found these two fuel line connectors. One is DORMAN Part # 800130(Includes Seals and Gaskets Needed for Installation; Spring Lock Coupling - Male: 11mm Conn.Body, 6.25mm Hose x 9.5mm Push Connect) and the other one is DORMAN Part # 800131(Includes Seals and Gaskets Needed for Installation; Spring Lock Coupling - Male: 14.17mm Conn.Body, 6.35mm Hose x 12.7mm Push Connect). But I don't know why there are two of them. Do you guys have any ideas about that? Do they both fit perfectly ? Also, I wonder they come with o-rings too. It says seals and gaskets included but just to make sure.
