MYSHO1
PiCkLe DaNcE!
What size are you turbo guys using? where did you find them? also will other styles work? mustangs?
For a boosted applications, 12:1 is safe in any case. As far as the duty cycle, you obviously do not want to max them out over their capability and you don't want too large of an injector. In general you try not to go over 80% of the injectors capabilities.SHO_Diehard said:Sho-Driver, what A/F ratio and duty cycle are you guys shooting for? Is this running the standard SHO fuel pressure?
Thanks,
Milt
.........................SHO--ripper said:SHO-Driver I'm curious what do you mean they were converted for the SHO?
Sho-Driver said:Also, the Bosche style pintle caps will have to be converted to the Denso style. Basically you take off the pintle cap.
what about your guys fuel pumps, can you use just a bigger pump, or are the injectors a necessity?
