fuel injection manifold question
LJRuddy
Pop lock n drop
Poaceae fields
I am trying to take the fuel injection manifold off of the engine and i cannot figure out how to disconnect the fuel supply line as well as the return line from the manifold. There seems to be some sort of release contraption on the line and i messed with it for a good hour and i could not figure it out... short of cutting the hose. This is making me feel very stupid.
Anyone know how to disconnect the fuel supply lines??
Muchos thankos!
LJ
Mr Anonymous
Tire Wall
Sure, get the right tools to release the garter springs from the connectors. About $9 for the set at Sears.
LJRuddy
Pop lock n drop
Poaceae fields
What exactly is the tool called?
btw, thanks for the quick reply! I couldnt sleep tonight thinking about this...
Minnesho
i was wrong
MinneSHOta
fuel line disconnect tools. they also service some ac and trans lines on certain vehicles. most parts stores will carry them as well.
LJRuddy
Pop lock n drop
Poaceae fields
I knew i was missing something... The entire hour i was poopin around, yanking cussing, yanking again. I kept saying there had to be something really stupid i was missing. Thanks for confirming my IQ... equal to room temp in a drafty building.
EDIT: w00t! post 220!
yamahaSHO
E85 whore
Arkansas
If you don't need to replace the rails, you can just take the rails off w/ injectors and swing them over to the side.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
And if you need to remove the rails entirely, you dont even have to disconnect those lines. Just unbolt the lines from the fuel rails. :shrug:
