Front suspension to-do list - Input needed
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
Once the snow melts, I am going to be installing my SHO Source Stage 3 Front brake upgrade including 95+ knuckles.
The car has 95,000 miles
While I am in there, I plan on installing the following:
- New SENSA TRAC struts since the originals are leaking.
- New Strut Rod bushings - Energy Suspension 4.7119 kit
Should I replace the springs?
is there anything else I should replace since I will have the whole front apart?
Thanks for the input.
VortecGT
Wisconsin
I would put on some steel brake lines. Springs would be a good idea if yours are original. But if you are going to do the fronts might as well replace all 4 springs and struts. Also inspect anything for wear and replace if needed IE balljoints, tierods, and subframe bushings.
NP SHO
Rice Killaaa
Windsor, New York
Replace all of it, that way you won't have to go back in there again
I'm in the process of doing this right now. Did the rear this weekend and doing the front next weekend. I'm doing SensaTrac struts, Intrax springs, Ingalls adjustable strut mounts up front/Monroe strut mounts in the rear, new strut rod bushings, swaybar endlinks, inner & outer tie rod ends...etc. I only want to do this once. FYI - If you live anywhere near the rust belt, plan on spending time heating and spraying the pinch bolts with WD40 or the likes. I spent over a day breaking loose my strut rod nuts and pinch bolts (part of which was drilling out the pinch bolt I snapped). HEAT IS YOUR FRIEND!!! Good luck and let us know what you end up doing.
eacyde
Pinkley Taurus
Thanks for the heads up. I am pretty sure the whole front end is original and it has seen some pretty harsh winters in its 18 years.
eacyde
Pinkley Taurus
I was going to upgrade the brake lines along with my 13" upgrade.
Is there a way to tell if my car has had the sub frame recall?
91PDXmocha
Portland , Oregon
-struts, strut mounts, springs , wheel bearings , inspect axles.
-ball joints , tie rods, sway bar bushings & endlinks , strut rod bushings.
-11.6 or larger front brake upgrade , steel lines .
Westerly, RI
Either take your VIN to your local Ford dealer, or www.ford.com. That'll tell you if there's any open recalls. However, to be 100% certain, I'd pull the front carpet back and have a look. Many dealers said they performed the recalls, but never did.
eacyde
Pinkley Taurus
What kind of drop can I expect from the Intrax Coils? Sho Source says 1.5" front and 1" rear.
Are those numbers realistic or is it actually more or less?
Thanks
NP SHO
Rice Killaaa
Windsor, New York
I just put them on the rears last weekend, but my car had that damned saggy ass syndrome, so it actually sits a little higher right now. Doing the fronts this weekend hopefully. Once I get them all done and I can take it for a ride to settle the suspension a bit I'll post up some pics.
NP SHO
Rice Killaaa
Windsor, New York
If you're thinking about running the Intrax springs, you should consider getting the adjustable front strut mounts. It'll make getting the car aligned much easier afterwards.
eacyde
Pinkley Taurus
What strut mounts should I get?
I will more than likely go with Intrax coils. I already have the Sensa Trac's. They went on sale buy 3 get one free yesterday. :)
I have strut rod bushings on the way.
What parts if any, can I re-use from my existing setup?
I was basically planning on building a complete strut setup so I can pop the old one out and put the new one in.
Thanks for all the help so far everyone.
