Just picked up a '94 ATX and the previous owner said the front strut mounts needed replacing. Loud banging from the front end when you go over bumps that sounds like the front of the car's going to fall off. I went over the replacement procedure on SHOTimes and it seems rather straight forward. I'm also going to check the other bushings in the front end while I'm at it, including the subframe bushings.
Anyways, I looked up the front strut mounts on FPN and I'[m having a difficult time deciphering the info. So, referring to the image below:
Mount bracket
17 - W/o police package
Is that the part I need to order?
Thanks
Mount bracket
Thanks
