Front Crank Seal
Whelen_Dealer
West Springfield
Front Crank Seal 95 ATX
I replaced the rod berrings last month.
As of yesterday i noticed smoke from burning oil coming out of my right side fenderwell after a 20 min warm up.
I went under it while it was running to see oil being dripped on to the cat. coming from what I can tell is the lower front crak seal/oil pan.
I took her to my mecanic who also looked at it and said I need a front crank seal. We went into his office and looked it up on ALL DATA and it showed my seal to have a total of 3 seals on it front,middle and rear all about an inch apart from each other.
I have looked at the past threads and I dont see anytrhing about 3 seal there only one.
If its only one and I dont have to remove the oil pan then i will do it myself (I hope)..
I had replaced the timing belt and water pump 6 months ago.
jelloslug
Digital
Greenville, SC
There is only one front main seal. There are 3 cam seals also, they are on the same side as the front main but they are high on the engine.
