Fog light problems
EMB2580
Mike is a L O S E R
Zion, Il
I posted a thread about this a while back but didn't get much response. A buddy gave me a set of original fogs, but they didn't work. Yes, fuse, switch, and bulbs are good. Anyway, I decided to test them off of the rear side markers...SURPRISE, they work!! which in fact, leads me to believe that the wiring in the car must be bad. My question is, what would be the best or easiest place to tap in to, heads, parking/turn, or front side marker? I think side markes would be the easiest. Let me know what you guys think, thanks in advance!! :thumb:
wood_e
The dude
Ames, IA
First check the wiring to see if you are getting any voltage through there.
EMB2580
Mike is a L O S E R
Zion, Il
Well, this is crazy, I finally said what the **** and cut off the connectors and wired it directly to the wiring. I now have functional fog light fronmthe fog light switch, YAY! On a side note they're not as worthless as people have said, I do notice a difference, mostly with peripheral sight.
