d-man-sho
Sorry, this is pretty long.
<story>
So, I got a fidanza flywheel, and after reading about how people have put the dowels in the wrongs spots and they have to be ground down and thinking "man that’s gotta suck," I proceed to put 2 dowels in the wrong spots.
Alright I take it to a friend and we try to drill them out. That was taking forever and I remembered that Fidanza just ground down pins in the wrong holes so that’s what we decided to do. We grind the two of them down, so I now have half a dowel and what’s left of half a dowel that was partially drilled out in the flywheel.
While doing the clutch job I put in new LCA, tpr bushings, ASFB, Extreme Reinforced motor mounts. I then proceed to install the flywheel and get everything back together. Start the car up and now it definitely is shaking a bit, though bearable i guess. I've never ridden in a car with these mods so I don’t know if it’s just extra NHV from them, but I think not.
</story>
OK so here are my questions.
Do the extreme motor mounts, ASFB cause a sizeable amount of engine shaking (probably not this much if its enough I’m posting about it right)?
Will 1 1/2 extra dowel pins in the flywheel cause problems? (Shaking, engine failure, deadly flying flywheel pieces)
Can I leave the flywheel like it is? Or dump the car quickly and find a super coupe (just an idea).
I've been going on the forum to ask about even the simplest stuff during this project, but for some reason I didn’t even think about the flywheel before i put it in. Gaar
As always help is definitely appreciated
-David
<story>
</story>
-David
that used the wrong holes! I ground all 3 flat. Almost 9K on it.
