A couple weeks ago I installed some new "mufflers" (actually resonators) that were Aero AR25's. I heard them on several cars and they sounded the best I've heard of any exhaust on these cars. I always think V6's are a tough engine to make sound good so I don't really like a lot of the muffler options. Once I picked up the car with new mufflers from the exhaust shop it sounded great at idle and when revving. But when driving, the drone in the cab was bad enough that I was going to fix the drone or return to stock. It droned pretty bad from about 2200-2800 RPMs. That drone resulted in the graph below (taken at 2500 rpm) where you can see the bad drone spike and smaller spikes at various octaves of that drone.
http://i184.photobucket.com/albums/x201/PwrRngr/30_Jul_2016_09_15_49_zpsinlvtmmi.jpeg
So I went back to some of my old acoustics knowledge (acoustics Engineer) and decided to build a Helmholtz resonator. I debated between a design with a neck and chamber (more compact design) or simply a longer tube that's capped at the end. After getting out the tape measure I opted for the simple tube since that would mean I only needed to buy one size tubing (2") and not two different sizes.
I looked at pre-bent exhaust tubing but it didn't have the bend radius I wanted so I ended up making my own.
So I broke out the cutter, MIG welder, and started going to town. Now remember, I'm an Engineer and not a welder. I finished restoring an old Mustang 10 years ago and that's the last time I touched a welder. So no, these welds are not pretty and I would not call them good. They are adequate and ugly but functional. Since no one sees under the car, I don't really care. Here I have created the two bends that will be used right out of the stock exhaust pipe.
http://i184.photobucket.com/albums/x201/PwrRngr/0803161920_zpsjer1t0ho.jpg
Then the exhaust came out of the car, I cut some holes, did some more welding, and it all ended up like this.
http://i184.photobucket.com/albums/x201/PwrRngr/2592_zpszwzfaetg.jpeg
Then the exhaust went back into the car, I let it warm up, and took it for a test drive. End result is below. This is a complete night and day difference. It went from an exhaust that I was going to take off and return to stock and changed it to the exhaust tone and volume that I wanted. As expected, it drastically reduced the 129 Hz drone and it also created a small peak at 68.5 Hz. When cruising it gives the car a nice subtle growl (IMO, how it should sound stock) and once you get into the upper RPM's you definitely can hear it. If anyone has drone in their exhaust they want to remove I highly suggest having and exhaust shop do this or doing it yourself.
http://i184.photobucket.com/albums/x201/PwrRngr/Capture_2016-08-06-14-38-18_zpsclka6mkq.png
