firewall
Bizzy
There are lots of ways to go through the firewall. There are lots of existing holes where things already go through, you may be able to use one of those. Otherwise, drilling is always an option, just make sure you know what is behind where you're going to drill before you start to do it.
SHO92
Upper Freehold, NJ
There is a grommet about the clutch pedal that you can use, or you can go through the hole for the antenna.
