Finding subframe bushing bolts.
blue2ndgen
Mi
I replaced the subframe bushings on the passenger side and reused the bolts because they were in good shape. On the driver's side though they are rusting away so I want to replace them. The Ford dealer has them for 6.44 a piece and they are not in stock.
Can I go to a building supply store or hardware and match up some similar bolts so I can save some money and get them sooner?
I did a search already and didnt find anything on substituting different bolts.
Note: I am replacing the bushings with gen 3's so I don't need washers and the nuts look fairly descent. Also the recall kit has already been done. This is why I don't think I need a kit.
thanks, Bruce
johndallara
Chapel Hill, NC
Bruce Malachuk also has these, he is an SHOforum member.
I believe this is his contact info. Bought 2 kits from him in the past.
Name: Bruce Malachuk, Albany, NY
Contact: 518-209-9773 or [email protected]
JD
e_clouser
04DrpTopGT
Near Harrisburg, PA
I tried a good grade 8 bolt and nut, I fabbed the nut kinda like the original... I see no difference in the way the car acts and I keep checking the bolts to make sure they are tight, with no problems. I am not saying do it, but it worked for me as I was in the same boat, could not wait for bolts to be shipped. Just as a side note, I have purchased the correct bolts and nuts, just waiting for a reason to put them in.:thumb:
JustinSane
SHO OFF
PA SHO Shop
i dont think the factory bolts are any more stout then a grade 8 bolt is. some one may have exact data on this.
blue2ndgen
Mi
Thanks guys for the help. I ended up finding a dealer about 25 min away that had them in stock. Over six dollars a piece, but definitely worth it knowing I have the right bolts on there and the 10.9 grade.
Racer X
SHO Pilot, Retired
Connecticut
JD
Dude, you missed April Fools Day by a few weeks.:rofl:
RCM has the bolts and the recall kits also (not listed on the site), as does most Ford dealers.
Grade 8 min tensile strength is 150K PSI and 10.9 is 142.2K. Also the torque capacity of the grade 8 is higher then its metric counterpart.
