Felpro Front Crank Seal
Bizzy
What a piece of crap. After doing my 3.2 swap I had a major oil leak showing from around the timing cover area. I feared the worst being the oil pump gasket. Thankfully I was relieved to find just the FCS pouring oil out of it.
Never again will I use a Felpro unit for that seal. Replaced it with a spare ford one I had on the shelf and the leak was gone :) I think I'll be ordering 6-8 of the Ford ones to put on my nearly empty parts shelf now just to be sure I never run out.
Just a little FYI to all those out there.
Ishodu
I found a CR seal that worked great also. I posted it a long time ago. Maybe a search will reveal the # once again.
Edit- found the # with a search
The part # is CR 16041. or CR 41*62*8 CRW1 R
The CR 16041 is the # to find, the other #'s are the dimensions in millimeters.
crystizel
