Wsho
I know they say bigger is better but my question is what's the best pipe size for our exhaust system I will be making my own exhaust system at my job looking at polished stainless but what's the best size 2 1/4, 2 1/2, 3 in 3 1/4 Etc
My plan post downpipes is ****** to a X where the third cat now resides then separate straight through resonators on each pipe instead of two pipes into one and ****** to the factory axle back.
I like how yours, SM105K, was made with the ability to bolt the factory set up right back in.
Then, cross my fingers as I fire it up and hope that it doesn’t sound like trash.
What have you read that leads you to conclude larger pipe would reduce scavenging on our engines?I’ve been trying to find information and read up on that. Still don’t know or quite understand all the specific science behind it but as of now my understanding is especially with our engines you would actually lose exhaust scavenging/flow with over 2.5”. I’m also convinced an X pipe in place of the third cat would be the ideal setup for our application as to both equalize back pressure and increase scavenging. it’s actually the perfect spot for it as well.
Right, but the comment was about specific to our engine. I was hoping to read what he has read on our specific engine
It all depends on the turbo efficiency from my understanding. Scavenging can be a thing.
You dont want the turbos restricted at all right? So like turbo diesels and even turbo added cars. Bigger better for exhaust. It dosnt really need to scavange i guess as its just being pushed out to get more in as quickly as it can. But i dont know, just my thinking.
All depends on the set up. That comp came video has some good points.
