Exhaust manifold to y-pipe stud
shoRunner
GA
anyone know where I can get a new or replacement. Its the thing the nut screws onto when connecting the y-pipe to exhaust manifold. Mine got unscrewed when i was trying to take the nut off because the nut was so stuck to it, it came out instead of the nut.
Dr.Evil
No Dif Pin!
Sparks, Nevada
why not just screw it back in with the nut still on it? thats what I did when that same thing happened to me...
shoRunner
GA
yeah I'll was planning on doing that...but I just like to know everthing is right with my car, and it seemed like something cheap and easy to fix to make better.
rangerj
Brunswick, Ohio
Shorunner,
Put in a new stud with anti-sieze compound. Then use brass nuts and a brass washer. Cover any remaining threads with additional brass nuts with anti-sieze and you will not have the same problem the next time. rangerj
Deaks2
Montreal, QC, Canada
I had 2 of the 4 studs break when I put on my new y-pipe this weekend.
The bolt/stud you need is a Metric 10. I used 4 new 45mm long bolts with Loctite and it is nice and snug.
