excessive brake noise...
Billy VK
Indiana
OK so I have replaced the brake pads and rotors on my 2013 with slotted and drilled rotors and ceramic pads from brakeperformance.com . I have issues with them being very loud when they get some heat in them... as in just coming off the highway and hitting them on the ramp. By the second hit of the pedal they are annoyingly loud. They were put on just this past winter and have about 10k miles on them. Would changing just the pads maybe cure this? Looking for advice. Thanks in advance.
OK so I have replaced the brake pads and rotors on my 2013 with slotted and drilled rotors and ceramic pads from performancebrake.com . I have issues with them being very loud when they get some heat in them... as in just coming off the highway and hitting them on the ramp. By the second hit of the pedal they are annoyingly loud. They were put on just this past winter and have about 10k miles on them. Would changing just the pads maybe cure this? Looking for advice. Thanks in advance.
The ceramic pads could be glazed and that is what is causing the noise. I would buy a new set of pp pads and go from there.
Joshw0000
North Carolina
Is it a squeel or a moan? Seems like the glazing would cause the squeel. Mine moan under a hard brake. I think my next set of pads will be EBC. They performed well, I just hate the brake dust they create.
Sent from my SM-N960U using Tapatalk
yaycandy
Aerospace Engineer
Hanover, PA
Could be alot of issues. Warped rotor, glazed pad, hung up caliper or pin, brake hose collapsed or wearing out internally, abs being stupid.
Billy VK
Indiana
I am leaning towards glazed pads. Everything else as far as performance of the brakes is fine. I have had some of those issues in race cars and it doesn't act like that.
I had the High Performance Z whatever Ceramic Pads from Powerstop. They were straight junk. Powerstop's Drilled and Slotted rotors are pretty good though. No cracks ect, and they have been beat ******* for about 15k miles. I threw the PS ceramic junk pad in the trash, and threw in a pair of stock PP pads and I am extremely happy now.
yaycandy
Aerospace Engineer
Hanover, PA
I had the High Performance Z whatever Ceramic Pads from Powerstop. They were straight junk. Powerstop's Drilled and Slotted rotors are pretty good though. No cracks ect, and they have been beat ******* for about 15k miles. I throw the PS ceramic junk pad in the trash, and through in a pair of stock PP pads and I am extremely happy now.
Same with r1 concepts. Rotors are pretty good but the pads that they come with are better thrown away.
RonPorter
SHO Club of America
Lake Orion, MI
Just make sure that you properly bed the new pads. If there aren't instructions in the boxes, check their website.
When switching pads, especially across mfrs, it's a good idea to get cleanup passes done on the rotors, or do it yourself with emery paper and a board.
Then you bed the pads and condition the rotors together.
