Engine support pictures
kmetros
Drug Pusher
South Bend, IN
Here's mine. Taken tonight. Hopefully I'll have it back together this weekend.
On a side note, the shackle you used to connect the brace to the engine doesn't look very robust. I overenginered mine and still try to stay out from under the engine when I'm doing other things like changing the steering rack - I'd suggest you do the same.
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
thecrew2999 said:
lol its not that big. its 182 c.i. not to mention its no where near 700lbs i think with heads and block its 400 lbs pushing it... wanna know how i figure that?
engine swap i had to move the 3.0 block with heads on it by myself and i had lifted it to move. so if it was close to 700 lbs id be in a lot of pain.........
hey man,
i meant with the tranny too ya know :nut: :thumb:
endri
yamahaSHO
E85 whore
Arkansas
CerberuS said:
NO WAY!
this floor is too clean...something is wrong...
My dad is ****. He keeps everything clean. I used to pull everything out of the shop once a month, hose it out, mop it, squeegie(sp) it dry, then put everything back in.
It helps that the floor is epoxied.
