motor mounts are super easy to get to through the wheel well behind the plastic crap, same with the tranny mount on the other side. You can leave all the accesories on it too, just remember to get the power steering line on the firewall side of the ps pump, it is a b*tch to get to. Thats how I do it so you can just put it right back in, hook up wires, bolt up motor and tranny mounts, and put all the axle cv shaft stuff back together and fire it up. Fuel lines are a ***** it you don't have the tool for taking the spring coupler on them apart. you have to take the intake off and unscrew them from the fuel rails buy the pressure regulator and pulse dampener thing. Go on autozone.com and go to the repair info and they have it on how to take the engine out without the tranny, I just unbolted and unhook a couple of extra things off the tranny to take it out with it otherwise you have to take all the accesories off to get the engine over far enough to get it off the tranny.
