Engine Rattle at 1500RPM
n2soccer21
Virginia
My '95 ATX engine just started to rattle. It rattles slightly at idle, then a lot at 1500RPM, but higher than 1500RPM it sounds fine. Could this be a valve issue, camshaft, or other? Does this sound like a serious problem? Roughly how much should I expect to pay to solve this problem?
Thanks!
Nick
Art5
white plains, NY
I had something similiar on one of my SHOs that I downshifter by accident. People told me that valves went out of adjustment.
SHOMON
95 MTX
MEDWAY MASS.
Timing belt tensioner. Pull the upper cover and start the car. When the one on my 95 ATX went you could see the belt go slack even at idle.
SHOMON
95 MTX
MEDWAY MASS.
Yeah could be the chain, but checking the timing belt on an atx is ***. As opposed to removing the valve covers to check the chain tensioner.
n2soccer21
Virginia
Believe it or not, I'm finally back in St. Louis for a couple weeks! More specifically, it's at 141 and Manchester. Think you could take a look, James?
Thanks!
KyngofPop
Freday-day
Charlotte NC
Use a stehescope on the valve cover or kinda feel it with your hand as you rev it, you're gonna be able to tell. I've got a hint of this but nowhere near as loud.
vortex2450
Buying Parts...
North Carolina
Cam chain tensioner is my bet, because the sound occurs AFTER you rev it and when the chain is most likely to get slack. See if it's close to the drivers side or pass side of the engine...
-Josh
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
If youre still driving it, you can bring it up to where I did the mounts on Sunday. Other than that, I'm stupid busy and cant make a trip out there anytime soon.
Thanks!
Mr Anonymous
Tire Wall
RPM-specific rattles are usually timing belt tensioners (or the crank cancer :eek:), but I agree in this case it's more likely a cam chain tensioner. Sounds to me like the delrin "shoe" is completely worn down or broken off one of the tensioners.
