millhouse913
I have a 94 ATX with about 120k miles. I've put a pretty penny into her over the past 2 years, Timing Belt, Water Pump, CPS, and most recently a rebuilt tranny in May. Over the past month I've had a pretty bad engine knock, almost sounds like Jiffy Pop, it started low but has gotten pretty bad. Performance doesn't seem to be affected other than some worse gas mileage than usual. I'm thinking probably "crank cancer" but not sure. Are there any tests i can do to narrow this down without ripping everything apart? Thanks.
