Engine noise, the never ending saga
1kirby1
Virginia
I replaced the rod bearings and I still hear this wobbling sound at low rpm like a pulley is loose but I've checked and re-checked all of them. I also drilled right through a broken stud and into the rear exhaust manifold, it's 3/16" in diameter. I looked at the helms for replacing the rear exhaust manifold and it's basically the lower half of the 60k plus some. I would much rather have someone weld it shut IF that would be considered a proper repare and I could get it done for a reasonable price ($50 - $100). I'm guessing somebody with the right equipment could do the welding in about five minutes once they got the y-pipe off, and that doesn't take more than about 5 minutes either, especially since I put all new studs on thumbs_u . What do you guys think? I need to do the valve lash, it seems like it would be cheaper to have someone else do it because I don't know what shims I need and I don't know of any shops that let you return the ones you don't use. Plus there are some special tools that I would probably only use once. Any ideas on this also? Thanks.
rob
DavidT
TN
Shoshop has a shim/tool rental kit, and so does Fordpartsnetwork.com (I believe)
It would be much more expensive to have someone else do it! I believe the kit only costs $50 upon the return of the kit and your old shims.
Mr Anonymous
Tire Wall
You might try removing your assy belts and turning the assy's by hand to see if one of them is responsible for the noise you're hearing. Could be a bearing in one of the idlers, the alternator, or a failing water pump.
Where in the exh. manifold did you drill, to the head, or the collector end? In either case a helicoil kit (~$5.00 at most auto parts stores) would be your best bet for a proper repair. I'd consider welding an absoulte last resort.
For the shim kit rental, you should also consider Josh at http://www.shonutperformance.com
Rob94
Northbridge MA
wobbling, or warbling, sound equals bad bearing somewhere. I have the sound, and it's the alternator. Do as SHOooo says, and try to pinpoint it. Definitely sounds like an accessory bearing.
1kirby1
Virginia
I actually drilled all the way through the rusted stud and into the bottom of the rear exhaust manifold where there should absolutely not be a hole at all. I don't think a helicoil is going to help there. I will check Ford Parts Network for the shim rental. I have read the sho shop is not the best when it comes to customer satisfaction and I fear they'd stick me with $200 of shims I don't need. Thanks for the help, anymore ideas of things that would make the sound described. After poking around with a wooden dowl it seems to be loudest on the passenger side of the left (or front) intake manifold.
hosbaldosho
