Engine hum in speakers
SilverSHO
cartersville
Whenever I have the radio on, I can hear the engine's revving as static in the speakers. It gets louder/more intense the harder I step into it (while I'm moving). I know it has something to do with spark plugs & wires, but I don't know exactly what.
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers (sound pretty damn good for $15 mufflers :D )
New to the family: '73 VW Beetle...MUCH less expensive to mod than the SHO, but somehow not quite as much fun ;)
AIM: loudog6491
T
ThatSHOkid
Guest
it is called "engine noise." do u have an aftermarket head unit or aftermarket speakers? if i am right, the hum increases whenever you step on the gas. well, most car stereo shops around here sell these things that go onto the wires in the engine bay and it filters out the "engine noise." to tell you the truth i think they are fairly cheap and work great. ask around on this baord to see if anyone uses them
1993 White/Tan SHO MTX 95k Miles
[*] Superwhite Headlights, Reverse Lights, & License Plate Lights ** Colgan Custom Bra From Cincy SHO ** Windshield Banner That Says "SHO" in Gen. 2 Font. ** Superchip Performance Chip ** Blacked Out "SHO" Lettering ** Sho Shop Y Pipe ** Coneless, Boxless w/K&N Filter Charger ** Blazertech Super Clear 55w Foglights ** Sunroof Wind Deflector & Vent Guards ** GTS Headlight Blackouts (on order) ** Sony 10 Disc Changer ** All Possible Options
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Strut Tower Braces, & A Sig Pic!
[*] My name: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
SHOstopper
Burlington, MA, United States
does it hum louder when your rpms go up if it does it's not the head unit its the ground wire either from your head unit but if u have any amp in your car its most likely due to a bad ground just try swicthing it, and if it still hums trun your radio up, and if that don't work just tell your friends that the turbocharger needs alittle work
SHOtime93
Michigan
It could also be that your RCA cables and your power wires are running too close to each other (assuming you have a system) just try running them on opposite sides of the car.
1993 White SHO ATX
Stock under the hood so far...
GTS Headlight covers
Saddleman Hood Bra
GTS Sunroof ventvisor
Tinted Windows
"SHO" windshield decal
"SHO" filler decals
400watt PPI amp and a single Fosgate HX2 12"
Powered by YAMAHA
yhardy1273
orlando,fl
Yes try to make sure that your RCA's and and power are not too close together. But before you do that if you have a amp with RCA with the car on and engine running remove the RCA's from the amp or head unit, if the noise goes away( which it usually does) go to Radio Shack and buy yourselg a RCA ground loop isolator. You will also need a female to female barrel conector.
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
AND A WHOLE LOTS MORE
yhardy1273
orlando,fl
Yes try to make sure that your RCA's and and power are not too close together. But before you do that if you have a amp with RCA with the car on and engine running remove the RCA's from the amp or head unit, if the noise goes away( which it usually does) go to Radio Shack and buy yourselg a RCA ground loop isolator. You will also need a female to female barrel conector too.
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
DeaconBlue
Cleveland, Ohio
SilverSHO, what ACCEL 8.8mm universal wires are you using? What does it say on the yellow wire jacket? If it says Spiral Core RFI Suppression, then your OK. If it says Stainless Steel Core, that's your problem. The Stainless Steel Core wires are non- suppression type and have very high EMI/RFI (radio static noise) radiation, enough to actually mess up the ECU and other electronics. If you are running the Spiral Core wires, then check and/or replace the condenser on the coil pack.
95 MTX
with a few mods
shooff
ranson wv usa
Its called "feedback"! And it definately is from the ground wire, not sure what does it but I think it may be the ground wire being too close to the power wire!!
