engine codes
mattsho1993
SHO owner
albion, new york
ok so i have my own odb1 tester but its just the kind that beeps and you count the beeps. here are the codes.... 511511117221954217221954???????
SHOspazz92
Banned
Triad Area, North Carolina.
Assuming you are doing this on your 93, Those should all be 3 digit codes. However, I don't know what a code 221, Or 954 is. I also don't see any codes listed for stock SHO's beating LS1's.
511 (O) No power to PCM pin 1 or bad PCM (processor)
117 (O,M) ECT sensor is/was low or grounded - ECT
217 (M) Primary circuit failure - ignition coil 3 - Ignition Systems
-Sam
