Emergency flasher inop
94SHO_Norfolk
Norfolk, VA
Strange thing going on with my SHO's emergency flasher...when I push down on the switch on the steering column, only the left turn signal indicator was blinking, so I walked around the car, and sure enough, the front right turn signal wasn't blinking...the other three were, but not that one. So I turned the flasher off, then checked the left/right and front/rear turn signals, both with and without the headlights on, and all four of them worked fine. So it must be something in the emergency flasher wiring going to the front right bulb?
