naval-avi8or
Just wanted to get a feel for what you GEN III guys/gals think about the Electronic Ride Control. Pro's, Con's or if anyone has ditched and replaced it with proformance shock (if so what ones). Any advice is appreciated.
Thanks
Curtis
Thanks
Curtis
The Koni inserts for the gen 2 will fit in the gen 3 strut housings, but the fully extended length of the gen 2 struts is longer than the gen 3. Combined with shorter Eibach springs w/o the weight of the car there is almost no compression at all on the springs. Since the springs were almost fully extended when I assembled everything, the final coil didn't lay down as flat as it would with another inch or two of compression. This made it a PITA to keep the front mount, bearing and seat all together.
