CplPflummUSMC
After having studied and searched this forum for info i have come to the conculsion that FI is the way to go. NOS is easier, but there is a consant cost. NA seems to be very very costy compared to the WHP that you can get (Area 91=258WHP not insulting just stateing what I have read). So haveing looked around I have settled on going with a SC. The reason for this is that I have a CNC shop with about a $1.5mil tool setup which should be able to fab a bracket easier than I can get someone to do all the welding for a TC. Looking at SC I see that some SHOs run the Eaton which can be had for less than $300 in many cases. Thought about Vortech or Powerdyne, but the cheapest that I have seen is abou $900 for just the headunit.
So having stated all that my goals are 300-325WHP with boost and about 25ish extra horsepower coming from bolts on such as Y-pipe, UDP and full intake/head work. So that would give me 325-350WHP. The car would remain a DD so reliabilty would be important. Also my budget is between $1500-$2000. I am not looking to get all new parts so I will save where applicable. Is this reasonable? Can it be done? Or am I just setting myself up for failure? Thanks again for all the advice. This is a great forum full of great info. Semper Fi!
Edit: I want to mount the Eaton where the A/C is currently located. I have no intention of building a custom intake so I am going to mount it on the bottom of the engine somewhere. Thanks again.
