Dual disk TC clutch
The latest Torque Converter I got has a HD dual disk clutch in it. Anyone have any insight about these?
93rev2sev
Hockeytown
There are disks on Tourque Converters? Whats a Torque Converter?
for that matter...whats an automatic transmission...
NebraskaSHO
Harumph!
Omaha
SHOZ, I'd guess it's more heavy duty than what you previously had, or stock.
What's the stall on it?
I know it is more HD. The normal ones only have one disk. I don't know the stall. The last rebuilt single disk one I had stalled at 2600 or so. I would think this one is a bit higher but won't know for a while.
Porkchop
The Black Sheep
Virginia
When I had my tranny replaced I had a HD aftermarket one put in thats like 300rpm or so looser (higher) than OE...
I like it so far!!!
SHO#7
Cincinnati
We just bought into a torque converter company... I will ask the head rebuilder there. I can not imagine how that would work. I have not seen the inside of our converters, but I have seen others. Most do not look like a common ATX friction inside. They tend to be a lining bonded on to a metal backing.
I will check into this Paul.
Does it have a hard lock up engagement....?
Mike
It is not installed yet. I was told the shifts would be quite firm and so I assume the TC engagement will be also. I have no problem with that and ran my TC lockup rather abrupt before on the other rebuilt TC. It held up very well and was just a standard fully brazed aftermarket rebuild.
Appreciate any insight you can give Mike.
SHO#7
Cincinnati
He stated that he has seen that before. He even made it sound like it is installed like that from the factory.
One friction ( just like in a transmission, only larger ) a molded lining on both sides of a steel plate, and a second friction.
FWIW he is an older guy, who may have some stuff confused about it being like that from the factory. But I stated I have a friend with a Taurus, and told him about the two frictions. He said " Alot of your SHO Taurus come like that. "
Mike
