bmcreider
Got Secondaries?
Ok...I've done the Intrax / Tokico swap...Aluminum SFBs...and the car came with those plastic HD Endlinks. However, the steering wheel has a little bit of play in it near the center...and the drivers side wheel, when I grab it at 9 and 3 and try to wiggle it from side to side, has play also. About an inch or more of play to be exact, if I do the same test on the passenger side it doesn't move at ALL....so I tried replacing the outer tie rod end...nothing changed....
any help?
any help?
