Drivers rear strut mount nuts...
wood_e
The dude
Ames, IA
How do you remove the carpetting back there to get at the nut closest to the outside of the car?
Mr Anonymous
Tire Wall
I usually just rip out the insulation. To get to the nut, use a prybar to push up on the seatbelt tensioner enough so you can get a ratcheting wrench on the nut (Gearwrench or such).
wood_e
The dude
Ames, IA
Thanks Chris! I'll give that a try... this hasn't been an easy suspension install...
Jonny Cash
Good boy
Hollywood, FL
I still couldnt even do it without completley removing the seatbelt. I tried prying it, but in fear of breaking it I just took it off.
wood_e
The dude
Ames, IA
Prying worked alright, but now I have yet another issue. When pushing the strut out of the hub I went too far and bent the area where the pinch bolt goes through. I expanded it too far.
Do I need a new hub? Could I try and clamp it back into position?
This suspension install has become a trainwreck
wood_e
The dude
Ames, IA
Alright, I was real worried there being this is my first time replacing struts & springs on a car.. Thanks Marcel!
