Emerald93MTX
Ok guys, I've had this problem for quite a while now and it's really starting to bother me; Every time I go from cruise to accelerate, the car kinda jerks. You can imagine how annoying this can be during traffic. Anyways, I have replaced my destroyed motor mounts with Shonut Reinforced mounts (tranny mount didn't look damaged), installed cup style Al SFBs, new TPR Moog endlinks, and even replaced my engine roll dampeners with some from another used sho. The motor mounts I installed seemed to lessen it a little and the torque is definitely being shoved to the ground now rather than making the engine rock, but the jerking is still there. The only things left that I can think might be the problem are tranny mount, swaybar bushings, tranny problem, or somewhere in the engine that I can't think of. I definitely think it is related to the transfer of power from the tranny to the wheels rather than an engine issue, but I'm leaving that option open. I have replaced the TPS sensor (adjusted to .97V), ECT sensor, cleaned MAF, cleaned K&N filter, and replaced IMRC. Oh, I can't imagine this is the problem, but I also installed a new 190lph Walbro fuel pump as well.
New water pump, new front crank seal, new plugs and wires, new front cam tensioner, new timing belt, new radiator, new intake manifold gaskets, new valve cover gaskets, etc. were all done about 10k miles ago.
One other thing is that when I had my clutch installed at 110k, the throwout bearing that came in the box with the Autozone clutch kit didn't fit and my mechanic (Vocational School teacher who doesn't make money on any of the work he does, other than being a teacher) said that the old one was fine and reinstalled that one. I know that my shifting has never really been the same since my old clutch started to go on me. When I bought the car, it shifted silky smooth, though I have never felt it that good since it disintegrated.
I try to keep the ATF fluid at proper level with a combination of 2 quarts Synchromesh and 1 quart Mobil 1 Synthetic, but I haven't checked it in a while. I don't think it would make a difference since it has this problem even when it is full.
I don't know of any other relevant info you guys may need off the top of my head, but let me know if I've left anything out. Help is always appreciated from all you guys on this forum.
Thanks,
Paul
Thanks,
Paul
finally some loctite held them in there
