door ajar?
1993shoguy
maine
well i pulled the sensors for the door ajar. I took each sensor out and unpluged it on all the doors. Then when i open the doors the door ajar light comes on is that normal or do i have an electrical issue?
Irish Pride
Irish Inside
MusicCityUSA
i dont quite understand what you mean. was the light on before? why did you unplug the sensors?
sperold
Last to Know
My door ajar light is on when all my doors are closed and it is killing me. Do new door switches make this problem go away?
Each door switch operates the dome light when each door is opened. What gives?
SHO SPD
SHO member #480
Naples, Florida
Yea, there is another switch for the door ajar.. Maybe one is stuck, try spraying the door latches with lubricant, maybe you can free one up
sperold
Last to Know
Am I fiddling with the wrong door switch?
It has me buffaloed. Each door switch does what it should when you open and close the doors individually. But when all the doors are closed, the light is on..... and boy is it bright at night.
I put WD40 on them (alot) but no change in the light.
Is tape my next move?
SHOMON
95 MTX
MEDWAY MASS.
I think the door ajar light is controlled by the door latch itself. The pin switch is for the dome light.
mattsho1993
SHO owner
albion, new york
every SHO ive owned is like this you learn to cope lol althought it is bright at night so is there a sensor in there or is it like when its closed it grounds and lights go out?
