Door Ajar Light
sperold
Last to Know
What is the quick test to determine which door sensor is bad. My light is always on and I don't have any doors ajar. This is on my 90, if that makes a difference.
tdoughboy37
lincoln, ne
I don't know of a "quick" test. I had to unplug each one, one at a time to find the culprit on my 94. I would suggest checking each of the door jamb buttons first. Visually inspect them to see that they push in and out properly. You may find the bad one that way, but will still have to unplug it to be sure.
shocrates
will never know
NJ
Spray PB Blaster into each of the four latches inside the doors. Open and close each door a couple of times to work the PB Blaster around. Your door ajar light will go out... eventually... unless one of the wires to a latch is broken.
tdoughboy37
lincoln, ne
That seems to be the general consensus for this problem. However, in my case didnt work (unfortunately)
Hope it does for you.
