1slickRED89
Guest
I decided to make a Low-buck leak checker today and thought I'd share it since it worked so well.
I got a PVC pipe cap with a ~3" OD and drilled a hole in it so to fit a automotive tire valve stem. greased up a stem and pulled it through. cinched it down where the MAF connects. sealed off where the TB is and added pressure till I heard "PSSSSS", worked well and I found three big leaks.
Bottom:
installed:
Bottom:
installed:
