diff pin diameter
nkb93
SLO 4 SHO
Charlottesville, VA
My driver's side halfshaft is stuck in the tranny and no amount of prying will break it loose. I'm afraid of busting the tranny case if I pry any harder.
I've got access to a machine shop and plenty of scrap steel, and would like to make one of these:
http://qualitytoolsforless.com/Product.aspx?ProductID=3032
Anybody know the approximate diameter of the long diff pin (MTX)? I need to mill out a notch on the tool to clear it.
Thanks,
Nate
93rev2sev
Hockeytown
prying never works for me, either. I have a smallish crowbar that I put between the cv housing and the case. A medium-light tap with a 3lb sledge hammer pops it right out.
Ishodu
A steady pry will not get it out, I usually just use a 10" bar and with a quick snap they pop right out.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Thanks,
Nate
the same diameter as the 2 short diff pins, which will be in the path of the tools two tangs. I suspect that tool won't work in SHO trannies. there is a cage in there too.
'bout 16mm for the pins
Perry
nkb93
SLO 4 SHO
Charlottesville, VA
Perry
Thanks for the insight.. I couldn't tell exactly what was in the way before, but now I see I would have surely hammered on the wrong parts with this kind of tool!
Guess I'll need to invest in a bigger crowbar and a hammer, per the above recommendations. Thanks to everyone.
Nate
