JOSHM
Hello all,
My question is regarding an inop fuel pump. Stopped working yesterday at the supermarket, left vehicle there and returned at midnight to work on it in privacy. Before I started I decided to try it just one more time...It worked, started and ran fine. I got it home and tried it the next morning and it again would not start and there was little to no fuel pressure and once again the pump could not be heard.
I searched in the archives and did some research on the wiring and components. I can hear a relay clicking at the relay control module above the fan. So i checked for power at the inertia switch in the trunk. I have 5 to 6 volts coming in and out of the switch yet still no pump sound. My question is will the pump run on 5 to 6 volts. If this is the right voltage then I suppose I will proceed with ordering a new pump. I did however find it strange that the pump worked, stopped working, and began working again. I have heard one member on this forum state that his plug kept coming loose at the pump.
Any help is greatly appreciated. I don't post much because I don't care for smart ass people. So if you are one of those please keep your comments to yourself. For the rest of you...thanks again for the help.
