Deleting A/C procedures?
jeanrw2000
Lechon Asado!
Brawley, CA
I was wonder if anybody here know the steps to safetly removed the entire AC system?
Thanks
Jean.
SASHO91
Zoom Zoom
San Antonio,TX
Just start pulling stuff off....
As for the A/C bracket, just gut the compressor and put it back in(with or without the belt) or make a plate for the bracket.
The only things you can really pull off are the condensor, lines, accumulator/dryer, and the internals (or whole)from the compressor. But that adds up to something like 50lbs...
jeanrw2000
Lechon Asado!
Brawley, CA
what about that little radiator looking thing infront the actual radiator?
as per A/C bracket i bought one from Rockautoparts
:dribble:
SASHO91
Zoom Zoom
San Antonio,TX
that would be the condensor. :thumb:
That could work, but you may have to make a bracket for it, so it will mount to the stock plate....
I would like to tell you that im have been running without the a/c compressor or any type of reinforcement on that plate for a year, but, you know....
It really is a good idea to reinforce it.. one of these days i'll get down in there and put a brace on it...
jeanrw2000
Lechon Asado!
Brawley, CA
so i can take the condesor out along with all conecting lines right?
so you are saying that is a good idea to build some kind of plate to mount the new A/C bypass pulley on it, for reinforsment purposes?
SASHO91
Zoom Zoom
San Antonio,TX
yes you can pull it all out.... but i would recomend that you have the system evacuated by a shop, instead of just letting it out into the air...
And yes, that would be a good way to do it. but you really dont need that pulley. FWIW, im just running a shorter belt, and have no issues with rubbing.
However, im not sure on the blower belt setup... so, you may in fact need that.. im not sure though....
jeanrw2000
Lechon Asado!
Brawley, CA
Cool, thanks:thumb:
dustin84
ohio
whats the length on the belt used to completely bypass ac clutch? think i might do the same...
im currently replacing the ac clutch and it's becoming a headache
jeanrw2000
Lechon Asado!
Brawley, CA
i haven't had a chance to do my with all the holidays shopping and work around my house so, i cant tell you the exact size but, i guess you can always use the old trick of the taking a line and wrapped around the pulleys and measure it to get the right size.
remember to loosen up the pulley adjusting screw before doing the measuring!:thumb:
