jtmartin8819
New to tuning and Datalogging...when I am datalogging, do I start from a launch, drop down, or rolling start?
Will be doing this on my lunch...Most tuners want two logs. From a stand still, traction off, 1st - 3rd gear pull at full throttle. Next log would be from a roll. Usually 3rd gear at 2000 rpm. Hold 3rd gear all the way to redline. That is usually it.
ThisAsk your tuner what kind of pull they want.
Most likely. In my SHO on 91 I get a bit of knock. On E30 I get zero knock.Sent first datalog to Torrie. Launch through 3rd gear (0-100). Said my knock retard is off the chart. Wonder if this is cuz I'm still trying to get the 87 out of my tank...?
Mother of God, the average boost is ~18psi, but the peaks! 28 and 41!!! Are those really the factory turbos?
Should probably take it easy on it till then huh?Most likely. In my SHO on 91 I get a bit of knock. On E30 I get zero knock.
In my ST on 87 it get quite a bit, on 91 a bit, and E54 zer0. Fuel is the most important part of the equation to make safe and reliable power.
Okay, that makes _way_ more sense that the system would be calibrated against vacuum.
Tip is actually at the throttle inlettip prs boost is measured at the turbo. The number you want to watch is the manifold absolute pressure. Peaked at 226 kpa however, that is relative to vacuum. There is a different formula. 226 kpa (relative to vacuum) is 18.08 PSI (relative to atmosphere).
Tip is actually at the throttle inlet![]()
