D4u1
Fordlover96
Virginia
Hi Guys, just me asking yet ANOTHER question again. I have been looking in the forum for instructions on how to remove the stoke PCM with one from a 94-95 ATX (d4u1). I buy one from RCM automotive and have heard that they imporve shifting. I just need someone to tell me some instructions how to do it! lol. Thanks again you guys in advance. Your life savers!
the pcm is located just behind the firewall on the passenger side. you will see the large connector on the firewall in the engine bay, just behind the power steering pump.
1. remove negative battery cable.
2. remove large connector from pcm. use care when removing the bolt to ensure that the connector comes off square and does not bind.
3. open glove box and release tabs so it swings down, out of the way.
4. remove bolt in plastic keeper that holds up the rear end of the pcm, and remove the keeper.
5. slide the pcm out the back.
reverse for installation.
