I'll sho u
Has anyone had luck with cutting the stock coils to lower their car? If you have how much did you remove?
jonny cash said:Do not cut your coils. People will tell you about cutting moogs, or other OEM coils, but it is really a stupid thing to do IMO.
All it will do is succesfully destroy the rate of the spring. You will bounce up and down like you dont even have struts.
Ask me about cutting, heating, and doing the most ******** things to distort a car that you can imagine. Ive done it all. Good thing the cars I was doing it to were Demo cars.
If you really want your car lowered, get some intrax springs. I saw them new on Ebay the other day for 100 bucks.
Shoaz said:If you cut dead coils you won't affect the spring rate, only the ride height. Cutting coils other than the dead coils is not advised.
Shoaz said:A dead coil is a coil that touches the adjacent coil all the way around. So it's not adding to the spring action. Typically these coils are there just to provide a flat surface for the mount. Whichever end it's on, that's where you cut.
The drop in the ride height will just be the thickness of that coil.
