Cruise Control Blues
94SHOusmc
Woodbridge, VA
Its been inop for the time I have had the car, 4 years. When I bought it it would work but only on flat ground, as soon as the road began to incline it would crap out. I never had it looked at and eventually it completely gave out. Anyone else had this problem????? Im about to take a trip down to GA again (Christmas at my folks) Its about a 8-10 hour trip and I have done it numerous times w/o it, but I am getting lazy and want it back. HELP me please. I dont wanna spent 75 bucks just to have someone look at it just to tell me they are gunna charge me more to fix it.
Rob94
Northbridge MA
I had a slightly similar problem. It would work fine, then crap out. I had noticed a hissing sound from under the steering column whenever the cruise was set, and upon investigation, found a vacumn line rubbing on the steering linkage with a hole worn in it. Replaced the hose, and all has been fine since.
Mr Anonymous
Tire Wall
Correct, the ATX cruise has no vacuum connection whatsoever. Check your codes for a VSS code. Short of that, it's usually a clockspring, control button, deactivator switch, or servo problem.
rangerj
Brunswick, Ohio
94SHOusmc,
See my response to Porkchop (hill?)in re. checking the codes for the cruise control. Semper Fidelis Marine.
If that doesn't point you in the right direction we'll do some other tests of components. Hang on to your $75.
My best friend served under Chesty Puller in Korea, and is one of the Marines that walked out of the Chosin Resivoir. rangerj
